I just got my fuel system installed and I am having a problem with fuel pressure drop. When I first start it up and the engine is cold, it has about 10-11 psi at the Mallory 4309 return regulator. But as the engine heats up, the pressure slowly starts to drop. Once it gets up to temp and everything gets heat soaked, its only putting out about 6.5-7 psi and if the return line gets blocked off, it'll push out about 8 psi. Why is there such a change in fuel pressure as the temps go up? Oh yeah, the fuel pump is an Aeromotive SS 150+ with an Aeromotive dead head style regulator right after the pump set at 12 psi. (My return line isn't quite big enogh and doesn't have enough size to bring all the excess fuel back to the tank at 18-20 psi. I will be putting a bigger return line on it sometime in the near future.)
1982 F100 - 357c w/ stuffed 4v's and Funnelweb. C-6 trans, Gear Vendors o.d. and 4.86 geared Detroit Locker 9" rear. http://www.supermotors.org/registry/vehicles/detail.php?id=6723
<font size=-1>[ This Message was edited by: f100cleveland on 5/3/06 7:48am ]</font>
