Need some advice/pics on the best place to locate my Aeromotive Fuel Pressure Regulator on my Fox Coupe. I will be installing a strut tower brace by the way. This will be on my 331 I just built. Thanks!
I have a fox mustang and mine is mounted on the passenger side fender apron, also known as the strut tower. Keep in mind though I have a carb motor so i'm not sure about what is already there on an EFI motor. Its a nice flat surface and its easy to access for quick adjustments. I would also suggest putting a fuel pressure gauge in line before and after the regulator while your already in there.
I decided to mount it on the firewall passenger side with an aluminum bracket. That is really good advice concerning the gauges. Thank You for your input. By the way I fired up my new 331 stroker motor recently and it kicked right off. What a joy that was, as I did the whole rebuild in my garage by myself. It was alot of work and alot of satisfaction. Thanks again!
