I got my inspection a few weeks ago and when the car was on the dyno the tech told me my air fuel ratio was at 14.5. I have heard this is around where you want it to run good, But that there could be gains if it is closer to 12. Is this true? Also right now my pressure is at 38 with the engine running and the vac hose off. With the hose on it drops to around 31. Could I pick up anything by adjusting the fuel pressure and if so which way.
