Is there a special type of wire used for the fuel pump? I had to replace the positive lead while installing a Walbrough 155. The pump did not include any additional wiring, and the stock wire had chaffing from rubbing on the bracket. I used standard power wire - radio shack stuff. Will the insulation survive in the gas tank? If not, what kind should be used?
