Any body know the ohm reading full and empty on a 62 Galaxie gas sending unit? The new sender reads full at full and enpty at 1/2 tank. It goes empty slow and steady but the tank is still half full when it gets there. I've replaced the gauge voltage regulator already and added extra tank ground?
10 ohms full to 73 ohms empty, +/- 10%. Your stock fuel gauge can also be calibrated to a good sensor. Do a search on the forums for the info.
:tup:
Have you gone back and checked the float on tank unit to make sure it doesn't have liquid in it?
