and yet another electrical question....... I want to hook up the wire to sending unit so i can tell when i'm going to run out of gas
I installed new tank/sending unit etc... i believe i found the small connector that goes on the sending unit "stud" and with only two wires left in trunk not being used. one is a black one that i'm pretty sure goes to licnese plate and the other (need to confirm) is a white one that is in the correct location to go to sending unit.
Hoping i have the correct connector and re-wire to tank tonight. Should this wire be "hot".....i'm thinking not and want to check before i wire.
Can anyone explain how this system works?
thanks
sixty3/kevin
thanks
sixty3/kevin
