Guys, I purchased this gas tank with an in-tank electric fuel pump for my '66 late last year and have decided I'm going to istall a fuel cell in the trunk instead. It is manufactured by Tanks, Inc and is a standard 16 gallon tank. The sender includes a Walbro 5CA401 pump which is rated at 29 GPH at 12 psi which should handle in excess of 300 HP. The fuel pressure should be regulated down to carburetor pressure after leaving the tank before going into the carburetor. Can be used with a return line system. You'll also have to get an aftermarket fuel level sending unit for the gas gauge. The whole thing retails for over $300. Make me an offer.
Thanks,
Mark
