1 - 11 of 11 Posts
Hi guys,
Has anyone tried using GM A-BODY lowering springs for their 65-67 galaxies? Spec wise, they look to be very comparable.
That would be an interesting addition to this forum!
A spring is a spring. If the specs are right for your application, then that would be the correct spring for you. There should be no concern over being a Ford, GM, Dodge, etc., spring.
Super Moderator
The only one i remember that did a lot of suspension stuff to his '66 doesn't come in here anymore and sold his car. Don't know if he did this one or not. Might search his threads maybe to see. He did a lot of altering.
ggrahn i think was the nic. You can search by poster in the advanced search section. I searched threads started by him but the info might be found in individual posts on someone elses threads. Below is from a Threads search
Ford Muscle Forums : Ford Muscle Cars Tech Forum - Search Results
On Moog's website they have a .pdf file with all of their spring numbers and spring rate/install height/load/diameter etc.....
It's good for comparing two springs to each other based on their specs.
If you have the time fine a stock spring that will lower it would be the much cheaper alternative. I would be VERY interested if you can find one.
Since you can run $59.00 Aerostar springs for on Fords up to 64 I guarantee there is one for 65-up...
I started a thread in 09 for 65/66 suspension upgrades. What I did in the long run didnt lower it but made the handling amazing for a large car.
1 - 11 of 11 Posts
