Here's the specs that I think I can duplicate.
306 with 9.57 compression with 87 octane, standard tension rings with low windage.
I put in AFR 165 flow#'s, but I plan to run TW170's.
Typical aftermarket long runner EFI manifold.
The cam specs are on the dyno run, but here's a link to the cam
Cam Spec Card :: Lunati Power
Here's the power. How accurate do you think it is?
