1...I saw this on Summit, Comp cams Magnum solid (part # cca-k31-336-4) 260/260 @ 0.050 (3-7k rpm range) comes in kit form (lifters, retainers, springs, timing chain/gear etc) for $420. How would this match up with a Vic jr intake, Vic jr heads, holley 750dp, 12:5:1 306ci bottom end (forged pop-ups-arp bolts), c4 (t/brake) with 4:11 rear gears & 26x10.5 MT drag slicks, weight is 2600lbs and what kind of stall would I be needing?? Car is 1/4 mile use only, would she be lazy off the line??
2....There is about a $100 difference between the Msd 6al & digital 6 on Summit (which I can afford now), is it worth the difference in performance or any other notable advantage to go with the digital 6 or should I just use the extra 100 towards some other acquisition....just wanna know if the 6al will get the job done just as well??
Any advice/guidance is welcome...custom grind is not an option right now as much as I'd luv to.
Thanx in advance guyz....
Thanx guys....Tony would you then suggest a milder cam with a lower stall?? or is that cam workable (no headaches) with a 5k stall, I'd so much luv to go custom but not able to just yet.. Are there any views on the 2nd question (MSD product)??
