1 - 12 of 12 Posts
Took the car for a decent ride today. Had to get on the hiway for a little while. 4:11's are low. Taching 3K is about 50-55mph. On the way back I had some issues. Car started bucking like you were turning the key on and off. At the time I was not sure what the issue was so I pulled over and checked all the fluids, etc. Everything seemed ok. Car started right back up and drove fine. ????? Seemed electrical. Maybe the MSD 6al box. Dont know.
Maybe the Falcon was confused what type of Ford it was and thought it was a Bronco. (ha).
Hope you figure it out.. I agree with FE probably electrical..
I had just filled up with fuel a few miles before. When I got home and shut the car down, I got alittle post ignition. Im leaning toward electrical. I want to change some things around anyway. I want to get rid of the "stock" alternator and get a 1 wire, and is there a way to get rid of the external voltage regulator? Any links to wiring diagrams? I want to make it simple.
There are many articles on F.M. for the swap. Just remove the regulator and any unneeded wires. I used a Ford 3G, re-clocked it, swapped pulleys and installed it using the old mounts. Two wires to the starter solenoid( the heavy feed wire with a 125 amp Mega fuse inline) and one to the indicator light. I was able to find an original harness that fit the new alternator. I think it was from a Fox body Mustang. It's been on there five or six years.
I'm thinking maybe a bad ground somewhere in the ignition. That's where I would start. I did have a fuel pump go out once and it did that just before it died, but if it drove fine after that it's probably not the case here.
I bought my polished one wire alternator from Summit several years ago. One large wire from alt to solenoid, that's it. After running it for a year or more without issues I decided it was time to get rid of the other wires and the regulator.
As you've probably figured out by now I like to keep things simple. :tup:
John
John
Did you use a certain wiring diagram, or did you just know what to do? If you used a diagram can you share it?
It was about three years ago so my memory is a little fuzzy. I recall that all I did was unplug the wiring harness from it and remove the regulator. The wires ran down the sides and along the front under the radiator I think. That entire bundle I seem to remember came out together. I don't recall cutting anything.
As far as the new installation goes it's just one short wire (pretty heavy guage) from the alternator to the soleniod so no diagram necessary.
John
Once you install the alternator, you can remove the voltage regulator for that clean look. I left the voltage regulator where it is for that stock look- but, I think it's also that innate feeling that if my 1 wire set up fails, I can just bolt the old one back.
There's nothing to cut during the install. Just remove the old alternator and the wire harness. Put your new 1 wire alternator in and mount the wire to the solenoid. To be safe-install a mega fuse.
Discussion Starter · #12 ·
Thanks guys. Definitely gonna do this
1 - 12 of 12 Posts
