Hello.
Sorry for bad English.
I've just rebuilt C4 (from 68'Mustang 289, 1964-1968 parts inside) with ATP FM-23 rebuilt kit and TransGo 47-2 shift kit. It was my first AT rebuild.
By the way, ATP's front seal is wrong, I've replaced it with Federal Mogul.
Also I replaced front pump bushing, direct high drum because of some cracks on it's bushing, also installed new kevlar TCI and DuPont bands and new TCI flexplate with ARP bolts. Mercon-V fluid (no way to find Type F at my location).
As a result I have very hard shift info reverse when fluid is hot.
All shift in drive position is good as I believe.
I suspect that I've mixed tight torque for the bands (inch-pound and foot pound).
Also ATSG C4-C5 manual and TransGo manual contains different data.
ATGS manual:
front/intermediate band - screw 13.5Nm/10lb-ft, back for 4.5 turns
rear/reserse band - screw 13.5Nm/10lb-ft, back for 3 turns
TransGo manual:
front/intermediate band - screw 10-12 inch-pound, back for 1.5 turns
rear/reserse band - screw 10-12 inch-pound, back for 2 turns
What is the right way for bands?
My torque wrench is Pittsburgh 3/8 Drive Torque Wrench with torque range 5 to 80 ft. lbs.
P.S. Transmission swapped into 94'Mustang with 1987 Ford 302 converted into 4BBL.
ATGS manual:
TransGo manual:
