1 - 11 of 11 Posts
aluminum disk? Or some other bolt on replacement for added strength?
I used a U joint I got off of Ebay on my old SVO. Made it steer like a go-kart. Much nicer than the rag joint.
I also had the later '86 SVO quick ratio rack, FWIW.
Have used the red nylon ones here as a replacement,haven't driven the car yet but should be a lot more direct than the rubber.
Banned
I used alumunim. You feel every bump in the road, but it moves whenyou want it to and there's no play in the steering. Rubber is for a soft, smooth feel on the steering wheel for comfort.
I have replaced the old rag joint with a borgenson u-joint. It is on a 1964 T-BOLT clone. Would you be interested on how I did it?
too solid and you may be looking at a safety issue, i had a friend break his joint and had no steering...so be careful
You can get a polyurethane disk that replaces the stock rubber. It is a lot stiffer and gives better feel, but takes some of the vibration out of it.
I had an extra one here somewhere, but I think it was misplaced in a recent move.
Still, they're like 7 bucks or so, cheaper than a U-joint and require no guessing if you can get it to work or fit right.
Thats the one I would go with if ours needed replacment!
This is on a power steering box and I take off the ps belt when I race the car. I have played with alighnment and have determined that the belt will just not stay on at 7000/7200 RPM.
I have been taking the belt off when I race but I have destroyed two rag joints. I have been looking at the borgeson joints but do not want to weld or drill anything, if there is a spline to spline direct bolt in I will go that rought. But if the red polyurathane rag is tougher maybe I should go that way.
Discussion Starter · #10 ·
YES do tell!
I ran into a problem changing my 84 t-bird power steering rack to a manual rack. The rag joint for the manual rack was missing so I could not install as the spline on the manual rack is smaller than tha power rack. I could not find a reasonably priced replacement so I'll have to go back to the junkyard and try to find one that works.
1 - 11 of 11 Posts
