I'm still having problems with this and need some opinions. It's a 331 with a 650cfm Edelbrock American Thunder carb. CR is about 9.2:1. Initial timing is 14° and total timing is 38° all in by 2500 RPM.
When the engine is totally cold:
I push the gas pedal to the floor 1 time to set the choke. I turn the key to the "on" position for a few seconds listening to the fuel pump run. When I turn the key to the "start" position, the starter engages and the engine almost starts instantly. I don't think it could start any faster. It runs at high idle until I blip the gas and it drops to normal idle.
When the engine is hot:
I turn the key to the "on" position for a few seconds and verify the fuel pump is running. I've tried not touching the gas pedal at all, pumping the gas 1 time, pumping it 2 times, pumping it 3 times, holding the gas pedal down half way, etc. No matter what I do, when I turn the key to the "start" position it tries to start 1 time but dies almost instantly. Then I have to let go of the key because the starter disengages the bendix. Then I turn the key to "start" again, and it has to crank, and crank, and crank... finally it fires up.
The things I know:
1. It's getting fuel as I can hear the pump running and my fuel gauge reads right around 6 psi.
2. The accelerator pump works, because I can see it spraying gas when I have the air cleaner off.
Please help! If any other info is needed, please let me know!
The things I know:
