i am planning a head swap (windsor jr,gt40p,or thumper e7)in the next month and need /want more compression.right now i do not know the values for the calculator provided here other than bore x stroke.i believe the easiest ways for me to affect compression in the comming tear down is milling the heads and head gasket choice.how much millig is safe and how thin a head gasket can i use.the other info you may need is that i woul like to use 1.7 roller tip rockers
