CAN ANYONE HELP ME WITH THIS? IT SEEMS THAT THE PASSENGER SIDE BANK OF MY ENGINE IS HOTTER THAN THE DRIVERS SIDE.
I NOTICED IT WITH THE STOCK HEADS AND ALSO WITH THE CASST IRON WINDSOR JR'S THAT I AM RUNNING NOW.
IS THIS COMMON: 1965 289 MUSTANG
You have discovered 1 of the reasons FORD re-designed the front cover and water pump in '86. They found as much as 20deg. diference bank to bank with the old setup. The main reason to fix it was emisions.
