Help on this please-
Nowhere in Edelbrock's instructions is the torque value given.
Heads are aluminum SBF (obviously), bolts are ARP stainless.
Bolt size is 3/8 and holes for the header fasteners are
helicoiled.
I would just snug them down by hand, not too tight, the last thing you want to do is strip any threads. I would probably say around 10 ft-lbs should work
Are you the big strong armed type? If you're not don't worry about it even with a 3/8" wrench chances are you'll never be able to tighten header bolts enough to strip them out.
Tighten them till they're tight, run the engine a couple times and tighten them up again a few more times and they should take a set and you shouldn't have to worry about again.
On 2006-04-17 15:53, 66GT289 wrote:
Sounds like a plan. I'll just use the 1/4 drive Craftsman ratchet.
I shouldn't be able to get into too much trouble with a 3-inch
handle
