Could someone tell me what header gaskets would be best, copper, aluminum, graphite, ect. I would like to do this only once. Also has slip fit on 2 tubes, should you use high temp silicone or something else. It's for street. Hooker super comp on a 5.0 Thanks
I have had no luck with the copper gaskets at all. They are way to hard. I find that the flanges are made very poorly on the headers. Run a file accross them to flatten them if needed. I like to cut the flange so each tube is independant from each other and use Felpro gaskets.
