I'm having a hell of a time finding a set of headers that will work with my setup. I've got a 1969 formal roof Torino with a 351w, FMX tranny and it will have AFR 185cc heads. I'm moving the shifter from the column to the floor and It has power steering (I'll be removing the A/C). I get a different answer from every tech number I call. I've contacted Summit, Jegs, Headman, Hooker and AFR. Summit says the Headman 88300 will work but Headman says they don't make a Header that will work with my setup (won't fit the heads). Summit says the Hooker 6116 will work Jegs says it won't and Hooker says it might. AFR says everything that will bolt to a stock 351w head will work with the 185 so I'm not sure who to believe.
Does anybody have experience with putting headers on a 351w with an FMX tranny in a 69 Torino????
Thanks for any help you can give.
jp
jp
