Hi, does anyone know of a set of performance headers that will fit a 72 mustang with a 351w and 4 speed manual transmission. I have bought a set of hedman headers but they require the clutch linkage to be modifyed
I was just about to go out and modify the clutch, but thought i'd check if there is another exhaust avaliable that actually fits!!
Check out my mustang rebuild blog for some pics...
http://mustangrebuild.blogspot.com/
Thanks for any help,
Marko (Scotland)
cant help with the headers but i checked out your sight and your build is nearly the same as mine.what pistons did you go with and what size carb are you going to use.those rpm heads work well on a street 351w,make plenty of torque.
Hi, thanks for checking out my site
Not sure what pistons were used as I got a specialist company to do the rebore and fit the pistons... I ended up modifying the clutch linkage.
Just got it on the road yesterday and boy it sounds AMAZING!!! Still needs a tune up and run in before i'll get an idea of the power. Although I'm not sure about the timing.. how many degrees btdc should it be? Do I go with factory settings on that?
If you got any ideas that be great... It's great to talk to someone with the same build up as me and know that it works well!!
Thanks, Marko
