I have the same exact issue on my 97 ranger. Very similar design in the heater box.
It could be the heater hose valve that sits in the engine compartment and shuts off the hot water to the heater core when you turn on the A/C. Mine stuck closed and it was cold with the heater on. Its cheap and easy.
Although Id bet my $65 to $75 on the heater door motor. Thats whats wrong with my heater-A/C. The Motor is a little geared box that sits on top of the heater box and controls the blend of cold and hot air.
Its a fairly cheap part as far as dealer parts go, But your going to have to drop the heater box assy to get to it
I havent changed it out because i just dont have the time.
all last summer when i needed the A/C it would blow hot air. unless it was on max. Then all of the sudden it was cold all the time , even with the heater on. Then I NEEDED the heater when it got cold and it took me cycling the ignition a few dozen times with the blower off and in dead silence ( so i could hear the geared motor work) took about a half hour and then finally i heard that dam thing move. Violia! HEAT!!!
So thats how i "knew" what the problem was. called the dealer and they quoted me $65 for the part.
Hope this helps!
good luck
it looks like this
71 Pinto
5.0 Roller block
B303 , 1.7 roller rockers, Crane beehive springs.
'68 302 Iron port polished heads.
Mod Must II headers.
Edelb Rpm Airgap
Holley 570
Msd dist ,Crane HI6 igntion
Bla Bla Bla
The money pit, "So... when will it be done?"
<font size=-1>[ This Message was edited by: 71hotrodpinto on 2/19/06 11:42am ]</font>
<font size=-1>[ This Message was edited by: 71hotrodpinto on 2/19/06 12:42pm ]</font>
