When I have heat on in the vehicle it comes out as hot steam. I definatly don't want to go through the hassle of replacing the heater core if it is something else. I'm thinking other possibilities could be the thermostat? Water pump?
Has anyone else had this problem?
Sent from AutoGuide.com Free App
Yes and 99% time it has been a leaking/weeping heater core but one time it was a loose heater hose that was seeping into the the heater core.
weeping slight leak not enough to cause a drip but enough to get the core damp then when you turn on the heater it can evaporate into steam.
