Hey guys, my car is overheating. I have an aluminum radiator and an electric fan. The car was running fine at 180 degrees and then it just started running very hot (above 230 degrees). I did replace the thermostat, water pump, and eventually had the heads checked. I did have a cracked head, so I replaced it and installed both heads with Felpro gaskets. I am still have issues with overheating and it is driving me insane. Did any run into an issue with this in the past and what did you do to fix the problem?
