I recently purchased a long block at a junkyard for 25 dollars not bad. It is a 302 and the heads are in great shape. I want to port them for my next engine build up but would like to know more about the heads. They say DBOE on the underside of the intake opening. They have the openings for smog equip. in the back. Does anyone know what these heads are off of and if they are worth porting?
Sure that wasn't D8, not DB? If so, they're 78 heads. Not much different than any other smog era head, but at 25 bucks, certainly worth porting if you have the time! Remember, labor is free, long as it's yours...
They are 302 heads (D8OE)and not the first choice (or 2nd for that matter)of most builders because the size of the chamber (69cc).
