I have a 1946 Studebaker M5 truck that was used to drag race. Suspension is custom with 4 link, 4 wheel disc and narrowed Ford 9 inch rear with 4:11 gears.
I have been unable to ID these rotors and calipers and both are stamped FORD. I keep hearing they may be Lincoln Versailles but I cannot find new ones anywhere if they are.
They sure look like Versaille calipers in pictures. One way to find out is to get Versaille calipers and see if they match up and bolt in. Your local parts houses should be able to get them and then they'd be easy to return. Take yours with you when you go to the store.
