1 - 8 of 8 Posts
Hello there everyone, I would be glad if someone could help me alittle here, These are the numbers from my tag of the rearend:
WDC-K
3.00 4HB 119.
The car is a 1965 500XL, 2dr HT.
It´s got the C5AW 4668A pinion support, With a large "cover" over the pinionsupport/yoke..
Any help is appriciated, Have great day!
Best Regards //Pontus Andersson, Malmoe, Sweden.
The 9" and 3.00 is a "clear thing", I should have written that i had those figured out, My bad!
What i need to know is about splines and bearings etc, Because i can get another 9" from a friends pickup with 3.73 gears for cheap, And i want to know if i just can loosen the shafts and then rip the whole assembly out and replace with the one with 3.73, Without running into any trouble.
28 spline.
You WONT rip the whole thing out. Truck is leaf sprung vs. coil spring for your 65
Just see if his has 28 spline and get the center section from him..
Wildo, I was talking about the center section
I dont remember from which year the pickup is..
5851a, Thank you very much! The axel is original then, Nice to have it confirmed.. I just hope the center section from the pickup is a direct fit?
1 - 8 of 8 Posts
