93 Mustang Gt 5.0 V8. Ok here how would I go about looking for a short if it is a short. There are times I go to start my car lights come on then turn the key nothing. I am able to touch the starter solinoid with a screwdriver then the car will start. If I leave the car sitting for a couple days the battery will be dead. Is all this intertwind. Please any help will be appreciated!!! Thanks!!!!!
sounds like you've got a bad ignition switch. Not working the starter circuit, and possibly leaving accessory circuits powered to kill the battery.
Finding the drain in your electrical is a very complicated thing.
Some mechanics will locate it in a matter of moments, 99% of the others will take a lot longer...
Electrical issues are a horrible way to start a week...
I do believe your situation to be slightly less difficult.
Check that ignition switch for sure! if the problem persists...
Issue: Occasional no crank with key, must use screwdriver.
Fix: Clean The contacts on the ground, the power and, all the leads going to the soleonoid and starter.
Your dead battery after a couple day's issue might be more of a non charging battery while driving issue.
See if that helps you. I'm sure it will improve something.
Signature contemplation still in legal process so as not to step on any toes...
<font size=-1>[ This Message was edited by: FALCONAROUND on 1/12/07 11:32pm ]</font>
Sounds like possibly two issues - one, clean all your battery cable connections, especially the negative cable, including where they bolt to the block or solenoid. There should be an engine to body ground strap - make sure it's there and clean it's mounts. The battery dead in a couple of days can be either that it's time is over or you have an electrical drain. You can hook an current meter between the battery and the positive cable - if it shows a load of anything significant (clock, radio, computer all draw a tiny bit of power), start pulling fuses until you find the circuit that has the problem.
