The only thing I see wrong is the cam is too small for that cubic inch and overall combo. Needs at minimum a 260 at .050 cam just to get the powerband to 6000RPM but that is easily fixed. I think it needs a rear suspension make over or serious tweakage to handle the power on launch. Now I know what my '68 Falcon wagon engine bay will look like with the big block. Tight yet right!
The cams a minor problem. The rear could be helped with some good TRI COUNTY springs. They flat work! Shocks are easy. Probably weighs 4200lbs.
