1 - 13 of 13 Posts
hey guys i'm new here but i've been at fordfe.com for a while thought i'd give this place a try, well my signature pretty much tells all about my car or at leas most about my car
Welcome!
My first car as a youth was a '64 I got back in 1984...
After 13 years of my second marriage I now have a 4 dr '61 Falcon!
yeah i'm 17 right now (be 18 in august) it was my dad's first car and my first car too and maybe someday it will be my kid's first car
That's COOL! I got my '64 just after I turned 18....
(about 2,000 years ago....)
Got Any Pics of the car. I Would like to see it.
Nice to see somebody else building up 66 t-bird
Fe 390
Tri power system from a 62 thunderbird
mallory distributor
adjustable rockers
edelbrock performer + cam
stainless steel valves
hardened seats
SCJ 16 bolt pattern custom shorty headers
pocket ported heads
mated to a T45 5 speed from a 2000 mustang cobra
4:11 richmond gears in a 9" g casting case four pin equa-loc
1200 watt system with 2 12" sub's
Tri coat PPG Prismatic red paint job
shaved door handles with remote opener
<font size=-1>[ This Message was edited by: casscomputers on 5/23/06 9:59am ]</font>
Link does not work! Try uploading pics to this website. Then copy and past line on the right window of your pics manager on this site to this reply pane. Watch out and make sure the pics are not too big. Resize them first before you upload. Be Looking!!!!!
Discussion Starter · #8 ·
yeah that link didn't work because it wasn't right
here's the link
when i try and put in the link it says fordmuscle.com and i can't type network 54 .com with out it putting ford muscle
Forum/76346/thread/1147017232/pics+of+the+66+bird+390+motor
put www. network 54 .com/ in front of that link with out the spaces
1966 Thunderbird
390FE
Offenhouser Duel Port Intake
Comp Cams XE274
Pertronix Ignitor
Pertronix 7mm Stock Look Plug Wires
Pertronix 40,000 Volt Coil
Holley 750 Vacuum Secondary Carb
1in. Carb Spacer
Melling High Volume Oil Pump
Edelbrock True Roller Timing Chain
Milodon High Volume Water Pump
Holley Blue Fuel Pump
Holley Fuel Pressure Regulator
C6 Transmission
2600 Stall Converter
TCI Shift Kit
B&M Clutches
Ford 9in. Rear
3.82 Richmonds
Full Drag Racing Spool
Tires
255 BFGoodrich Radial T/A in Back
215 BFGoodrich Radial T/A in Front
<font size=-1>[ This Message was edited by: 1966Tbird on 5/24/06 6:32am ]</font>
<font size=-1>[ This Message was edited by: 1966Tbird on 5/24/06 6:34am ]</font>
<font size=-1>[ This Message was edited by: 1966Tbird on 5/24/06 6:36am ]</font>
I now have a 93 Bird, but have had several over the years. I wish I had my 59 still. It was one of the few that had a 430 CI engine.
Don't be lazy and not post pics on this site. 1966 tbird! By the way, the air cleaner on the box infront of the car is worth $150 - $200. Most are lost when replaced like you did or rotted out.
No foolin'? $200? I'll gladly pull the cleaner off my '66 bird for that money. Any other high demand parts? Maybe I'll part out my car...
Hi,
I'm a new member. I've been driving my 64 Falcon as my daily-driver and slowly...very slowly restoring my 66 Thunderbird. I would appreciate any advise and anecdotes on the 66 T-bird. I'm looking for a place that rebuilds carburetors on Long Island for starters.
Thanks,
Tom
1 - 13 of 13 Posts
