I was thinking 11:1 on a 331 stroker with a 100 shot for the track. AFR 185's, custom cam, and a 750 carb, long tubes.
What kind of numbers do you think this would make excluding the nitrous?
I want to be able to run 93 octane with out nirtous.
should be in the 12s on the motor with the setup like that....
12's with motor and 11's with the 100 shot
My 80 coupe runs 11.90's with a similar set up less the nitrous. I run a 331 w/ 12.1, brodix heads, custom cam, 4.30 gears and a 5 speed on slicks.
Mid to high 11's is my guess.
