67 Fairlane manual drums.
so Ive recently have done a complete brake job on my Fairlane-shoes, MC, a wheel cylinder, new spring kits, full fluid flush, drums turned.
But the front right wheel is very grabby, so I get under it to adjust the star wheel, and low and behold- its already backed off all the way. the shoes aren't touching, but the wheel is very hard to turn by hand. I take it all apart, and see nothing rubbing, so I put it all back together, and still hard to turn.
So I just put the shoes on, no hard ware except I put on the shoe keepers(those small springs that hold the shoe to the backing plate) and the star wheel, and wheel cylinder so that the shoes would be sitting right where they should be.
I put the drum back on, and spins just fine, no drag.
So i put it all back together, torqued the spindle nut to 22ft./lbs, and then backed that off, and finger tightened it, but it still drags alot.
Mind you, the car has been sitting for a couple years. Could the wheel cylinder be locked up? I took the rubber boots off, and had gelled brake fluid in there, so I cleaned it out, but like I said, it spun free when I just had the shoes, cylinder, and star wheel in there.
Bad wheel cylinder? or warped backing plate? All other wheels spin free with the adjusters backed off except this one.
