I need to relocate my holley blue, and the spot I wanted to move it to requires to lay on it side, as opposed to the normal upright position. My question is has anyone mounted theirs in that position and does it work correctly?, Holley techs say it must be mounted upright for it to operate correctly, I don't understand why, as it is an electric motor and I think it should work any position
Mick
if you lay the pump horizontally you can experience vain chatter. you're pump will work but, the norm is you will get pressure indifferences. don't do it. good luck, ron.
my everyday street racer:
'91 gt, 357", track heat heads, victor efi upper/lower, custom comp cams retro roller, nitrous works 260 hp 2-stage plate, 3800 10" no2 converter, holley digital ignition, bbk/edelbrock 75 mm throttly body, homebuilt c-4 (a big thanks to gregaust! ) 4.10 gear, 12.5 x 28 et streets.
<font size=-1>[ This Message was edited by: rj on 6/10/02 3:02am ]</font>
