I am rebuilding a Holley 650dp. Are the springs on the floats supposed to force them up or down?
Hey dragman..........the spring on the float lever shaft is an assist spring that helps lift the float up when the bowl in in its normal posistion........the little tab on the spring goes into the hole on the flaot arm,then around the float pin and then up under the left mounting screw in the little notch in the bracket...WHEW.....thats confusing HUH?........Good luck...Jesse @ BIGS
