I have an old 750 d.p. that I put on a proform main body. But I think that this problem was there before I did the main body change (it was years ago). I had the engine dyno'd so I know wide open throttle the air/fuel is right where it makes the power and is Plenty safe. Problem is cruising. Even just sitting there, if you open the throttle to "off ide" circuit, you can see the fuel dumping in and the motor actually kind of burbles. Thing smells WAAAAAAAAAAAAAAAY gassy. TERRRRRIble fuel mileage. Is this off idle circuit in the main body or is it in the metering blocks??
How old are the metering blocks/screws? If they get worn, they stop metering fuel flow and you get a rich condition. Also, the air bleeds could be plugged, floats sunk, etc. etc.
I'd imagine you've tried tuning it all that you could. If you turn the idle screws in all the way does it die?
