I just finished putting a pair of 450 vacuum secondary Holleys on my Weiand Tunnel Ram on the 289. Runs pretty well for the stock tune, but I have a few questions:
1. The vacuum secondaries seem to be a little slow, both on the opening and especially on the closing. This is a 5-speed manual trans, and when I've got it wringed out and let off the gas for a quick shift, it feels like there's a shock absorber keeping my pedal from closing quickly. Looking at how the carbs operate, I think it's the vacuum canister taking too long to bleed off, holding the secondaries open which in turn holds the primaries open due to the linkage. It's not disasterous, but it gives me a feeling like I'm not in total control of the throttle. There is a tiny orifice in the top of the vacuum canister bottom-half, that I believe is responsible for controlling the rate that the canister can breath. I think the solution is to drill out this orifice slightly, like one drill bit size at a time, until I'm happier with the feel. Does this sound right?
2. The idle doesn't seem horribly stable. I can get it down to a rich 1000rpm idle, but if I try to go any lower it stumbles, leans out, and dies. The idle air bleeds are huge on the primary side, I think I may try putting a wire in them to choke them down a little and see if that helps. I'm wondering if the cure is to back out the secondary throttle stop screws a little? The problem with that is, they are both pretty well frozen into the carb base plates. Any suggestions how to get them un-stuck?
Anyways, any recommendations on tuning a dual-quad setup in general will be welcome. As mentioned it ran pretty strong, the secondaries may be opening a tad late, but maybe my above fix will help with that without adjusting the spring. There was also one time I floored it from about 2500rpm, it leaned way out (on my wideband O2 gauge), bumbled for about a second, and then like a light switch it pulled in rich and took off. Not sure what the lean out was about, might be I need more pump shot, but that's easy enough to avoid by not just mashing the pedal.
Thanks!
Thanks!
