what would be a good carb for a healthy built 302 for race only we turn it 7500 rpm a 750 dp or a 850 dp. Vic Jr intake, WP Sr heads
260 @ .050 cam 591 lift solid cam. behind a 4 spd.
Alan
Radracing..........I would have to reccommend a 750 for your application.........The problem with the 850 is the large venturi area it has(1 9/16) compared to the 750 with 1 3/8.....The throttle responce will be much better with the smaller venturi.........I have 2 stages of my BIGS 750 race carb if you are interested..........My Stage 5 HP is an all out race carb that flows over 800+CFM at 7500RPM and will do all you need........It can be seen on E-bay its item #1804779315.....I also offer my Stage 3 which cost a little less but has all the same features as the stage 5 with the exception of the contoured and shaped main body........I can sell my BIGS Stage 3 to you with the choke horn removed and fully race prepped for your application for $449..........Thanx alot and good luck....Jesse @ BIGS
