1 - 16 of 16 Posts
There have been from time to time questions about building a manual valve body at home. Well I built a reverse manual at home it was a lot of fun. From my experence I would never try it again. It only cost about $10 to do, but it took about eight hours including the planing. My sugestion to anyone wanting to try it SPEND THE $200 ON A PA. You could also buy the kit from Jay if you must do it yourself. JMHO
P.S. don't bother asking me how to do it cause I won't tell you. I wouldn't want to put anyone through what is involved.
<font size=-1>[ This Message was edited by: Freddie on 10/25/06 10:28am ]</font>
Ok then..BUT a few details on how you did it would be nice to know.
<font size=-1>[ This Message was edited by: gregaust on 10/25/06 6:59pm ]</font>
Red lines are cuts, Blue is blocked with JB weld.
<font size=-1>[ This Message was edited by: Freddie on 10/26/06 8:23am ]</font>
<font size=-1>[ This Message was edited by: Freddie on 10/26/06 8:28am ]</font>
Jay's kit is a lot less work than that. At $75, it's an excellent buy.
That looks very much like a copy of a popular brand VB. What about mods to i think it's the valve beside the pressure reg valve which is plugged off? Also there is a hole drilled through the top of the upper valve body in the lower area beside the blue dot. What other mods other than the cutouts?
I'd guess no engine braking in 1st?
Thanks for posting pics, now I can check and odd VB I've in my parts bin.
Is Jays kit better than a -3 kit?
More info? Thanks.
I just did a Jays kit. Cost $75 and took me all of 20 minutes to mill the 4 channels that needed cut. Shifts very firm although I went a bit overboard on the optional pressure relief washers and ended up with 300+ lbs of line pressure so I'll have to drop the pan and remove the washers to get the line pressure down before I do much dragstrip flogging. Cant race till april anyway.. I would and will use one of his kitd again.Simple and well thought out and no 2-3 flare .
Anyway to make a Manual Reverse with engine braking in 1st?
Anyone? (thanks)
Have more info or a link I missed while searching? Thanks!
<font size=-1>[ This Message was edited by: MisterN on 11/1/06 8:29am ]</font>
Now that is cool.. Sweet work i think..
How would you then set it up for a trans brake?
I don't care about engine braking in 1st but it would be nice not to have engine braking in 3rd with a manual VB.
broaderperformance.com
The -3 kit from TransGo is reversible - you can undo the manual and put it back to auto. I don't think you can do that once you start cutting passages. The 1970 Maverick came with a manual valve body - its not as hard as you might think - so long as you don't want a reverse pattern.
Paul
No engine braking in first....
Does this mean that the low servo is not applied in low gear, allowing the sprag to bear ALL of the torque?
1 - 16 of 16 Posts
