--- Robbi's port work
dark7068 - 6:09 pm on Dec. 3, 2001
exhaust port before
exhaust after
combustion chamber before
after
Good job Robbi.
Rick
68 Fairlane 500 Fastback/70 Cougar Eliminator
Edited by: dark7068
dragman64 - 6:30 pm on Dec. 3, 2001
WOW!
1964 Comet 289 C4 daily driver
"These go to 11." -This is Spinal Tap
1965FALCON - 6:31 pm on Dec. 3, 2001
Looks Great!
They look almost exactly like the ones I just did for mine! I did the same thing on the valve guide boss too.
What size valves are you going to put in them?
1965 Falcon 289 C4 Hardtop
(After I finish the 6 to 8 swap)
Robbi - 6:41 pm on Dec. 3, 2001
thanks Rick,
I have finished only 3 exhaust ports and one intake bowl ,to make some pictures .
Now I will port the last exhaust channel and then the other intake channels .
Then is time to make more pictures !(sunday nigt)
When I removed the frost-plugs of these heads ,I saw how thin the cast channels are,
you cant grind everywhere so much , so I will be carefully.
It need to spend a lot of time to do a good work ,but think its worth.
Thinking about 1.94 and 1.60 valves
Edited by: Robbi
Robbi - 6:47 pm on Dec. 3, 2001
Hi 1965Falcon,
do you drive this heads now?
64 TBOLT - 6:50 pm on Dec. 3, 2001
what are the heads and what year? Appear to be older heads cause of the big plug
64 FAIRLANE 460
Robbi - 6:57 pm on Dec. 3, 2001
oh I forgot,
this are ´66 289 sb heads casting # C6OE
FasterDamnit - 8:14 pm on Dec. 4, 2001
Well Done! They look a LOT better than my first attempt! Can't wait to see the results.
Jim L.
Technical Editor, Fordmuscle.com (65 GT, 289, T5. '92 LX, 5.0, AOD.)
1965FALCON - 11:54 pm on Dec. 4, 2001
Robbi,
They are still sitting on my bench... I had 194/160 valves installed and they look good.
They do shrink up the chamber size though, even with deshrouding. Mine are around 52 cc's now.
Have you started on the intake runners yet? I'd like to see how they turn out for you!
I'm still trying to figure a good way to gauge the thickness around the pushrod holes. If you think of something let me know.
Bruce Haunreiter
Robbi - 7:02 am on Dec. 5, 2001
Hallo Bruce,
I just find time to to work on my heads on sunday. I will tell you how it goes on and send some pictures more,
can you send some pics of your work?
Pale Rider - 9:16 am on Dec. 5, 2001
Robbi, that looks really good. You will be happy with the results. Keep us posted.
1965FALCON - 12:59 pm on Dec. 5, 2001
I'll send some pictures if can borrow a digital camera from work (and I can figure out how to post them)
Robbi, what part of Germany are you from?
I have some relatives that own a used car dealership "auto Haunreiter" in Marktl near Munich
Bruce Haunreiter
Robbi - 1:08 pm on Dec. 5, 2001
I am in Essen , that´s about 600 km from Munich.
The world is small !
67stang - 1:20 pm on Dec. 6, 2001
wow! zee german is talented with the die grinder! nice work
dark7068 - 2:44 pm on Dec. 6, 2001
65FALCON, I you cant figure out how to post, send them to me, I will help you out.
Rick
1965FALCON - 2:50 pm on Dec. 6, 2001
Thanks Rick,
I'll see what I can do tonight and practice my photography...
dark7068 - 6:39 pm on Dec. 14, 2001
Afew more of his porting work.
1965FALCON - 7:05 pm on Dec. 14, 2001
I'm inspired!
Robbi - 8:00 pm on Dec. 14, 2001
Thanks Rick,
This port is not finished.
At first I grind only the first two centimeters to match nealy the gasket-size.
It is very important to do the end-gasket-matching when they are milled (if needed).
so be careful at the bottom of the intake.
Hope it helps.
To check the clearence betwen the intake-runner and the pushrod-holes put in a pushrod and make a sign .
<font size=-1>[ This Message was edited by: admin on 12/27/01 3:13pm ]</font>
<font size=-1>[ This Message was edited by: admin on 12/27/01 3:15pm ]</font>
<font size=-1>[ This Message was edited by: 67stang on 10/22/03 2:55pm ]</font>
exhaust port before
exhaust after
after
Good job Robbi.
Rick
Edited by: dark7068
WOW!
Looks Great!
thanks Rick,
Edited by: Robbi
Hi 1965Falcon,
64 FAIRLANE 460
oh I forgot,
Jim L.
Robbi,
Bruce Haunreiter
Hallo Bruce,
Bruce Haunreiter
Rick
Thanks Rick,
I'm inspired!
Thanks Rick,
Hope it helps.
