Discussion Starter #1 (Edited by Moderator)
Homemade Flexplate Handle.
There comes a time in every engines life that the flexplate need to go on. Being alone on a lot of my build my mind wanders. I admittedly over solve some things and this might be one of them.
I probably could have got away with bolt jammed in a hole or something, but hey, a chance to make a tool. This saved me some grief and allowed me to tighten the flexplate bolts without help from anyone. I had a 28" scrap piece of 3/4" square tubing that turned out to be perfect. My intension was to keep the work to a minimum. I looked at the holes flexplate and measured the bolts on the torque converter and came up with 8-1/4".
I center punched my holes and used the drill press to step through three dill sizes to 3/8". Then deburred the hole.
I got my two 3/8" X 1-1/2" bolts from my vise on my drill press.
Testing the fit, I realized that I needed to space it out a little. A washer took care of that.
I ran the bolts from the front and bolted it up. Now I could tighten the flexplate bolts that I needed to get to 80 ft-lbs without issues. This tool allowed me to tighten the crank damper bolt while it was on the engine stand.
An idea. Same basic set up but with a angled handle so you use it with the engine still in the car.
Also how different would it be for a manual flywheel?
If your talking about when the trans is removed, a couple of pie cuts and welds would be easy. Make a Z bar out of it. I wanted a nice and easy tool that didn't seem jury-rigged and I didn't need to go fancy. Putting a piece of heater hose over the end would make a good handle too.
I don't have much experience with flyweels. I think some have holes toward the outer ring that would work if the clutch is not installed.
Way to simple of tool. Probably why it works so well. The KISS method is always the best way.
