how much hp would this combo produce
1970 351w 30 over
1970 dooe 351 heads ported polished ss valves screw in studs with guide plates
wolverine wg 1088 cam
performer intake with 600 cfm carb reworked to match the combination
cam specs .050 dur. exh. lift .520 dur 300 int.496 adv 290
how much timing advace should this take? thanks
That Performer intake is going to hurt you if you're going for a lot of power, it's a low rpm intake, smog legal, the RPM is much better. I had a similar setup last year on my '69 with a little less cam and the Desktop Dyno said 303 hp. The biggest improvement I made was going to the RPM intake.
