Ok
That looks like it is the green dot valvebody.It should have the D1 + D2 on the shifter .There are no checkballs but i have marked the flat disc that is used as part of the accumulator circuit which is used to give smooth shift in 2nd gear.You can leave it out will firm the shifts as most shift kits do.
That drum,try cleaning it up with like 150 grit emery tape.If it comes up smooth i'd say use it.If the blue marks dont polish away or the heat marks are still visible or slightly raised i'd toss it.The other drum being later you will find is different on the inside diameter.Any doubts on the thrust washers just replace them.If you get stuck for parts try Jay @
www.broaderperformance.com .
I do have a diagram of that V.B i can scan if you need it....Greg
