Help. I can't believe I don't know how to do this but how do I get the antenna out of a '68 Mustang. I can't find the nut from inside the car and I don't see any other way to access this area(apart from pulling the fender). Also, has anyone put a power antenna in and how did it work out?
There should be a retaining nut at the base of your antenna. There is a locking device that that rotates in the hole and locks to the underside of the fender. Rotate it until it clears the hole. Some later Fords had a chrome plate that clipped on top of the base and when it's popped off there are 4 retaining screws.
Ive looked into this too, and form what i see, the best way to do it is to pull the fender
, I know that doesnt help much but I think it will save you time.
catch you later,
You will have to pull the fender unless you are a contorsionist with tiny arms and can find a way to remove the rear splash guard. Pulling it isn't too bad. There are the obvious bolts under the hood line, one accesible with the passenger door open, you need to remove the front bumber and headlight but can leave the headlight bucket in place. There are a few bolts that need to be removed from the front valance and stone guard assemlies and get the wiring out of the fender oh.. and there are a couple/few bolts attaching the bottom of the fender to the car. carefully lift the fender off and put it in a safe place. Now the antenna is easy to get at. good luck...Lee
