NumberDummy
Ford Parts Guru
Garage is empty, add now Join Date: Nov 2006
You have the Bendix inertia type of starter drive (C2AZ-11350-C ~ Motorcraft SD-132), it comes as a one piece assembly: Includes the gear, housing and large coil spring.
It's retained on the starter armature shaft with the "drive pinion" (drift) pin (C2AZ-11365-A). You have to 'unwind' the starter drive to gain access to the pin...to drive it out.
It's a snap to unwind it, but...when this drive unwinds, it can be a PITA to get it back into position.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo
vehicles.
