If it was externally balalanced used the flywheel and dampner, that means I need to get a new dampner balance matched, right?
What about later when I rebuild the engine?
All FE's have a neutral balanced damper. 428 SCJ's have a weight on the spacer behind the damper but there is still no weight on the damper. All 428's & 410's have a weight on the flexplate or flywheel.
