Yes loose is bad. Try to get it on the low end of the tolerance.
Try get down to at least below .020.There are thin shims available to go under the #1 +#2 thrusts if you cant get thicker thrusts.
Easy to work out.If you now have .057" endfloat,measure your #2 shim.You need to add say .040-.045" to the #2 thickness, then reset your #1 after.
