Just wondering about a rough estimate for horsepower.95 mustang gt 347 stroker. block has been decked and blueprinted. Aluminum procomp heads with 210 runners and 60cc chambers. Edlebrock performer upper and lower intake with 3 inch plenum spacer. Trick flow studded floating roller rockers. Trick flow cam with 512 lift i believe. Mallory distributor. 8mm wires. Procomp crank rods and pistons. High volume oil pump. 33lb injectors. Msd coil. Ac delete smog pump delete. Cold air intake. Slp loudmouth exhaust with x pipe no convertors. Computer was chipped and tuned.
