Hi,
Sorry if this has been asked a million times.
My C4 has a B&M deep cast pan and PTC spragless 8" converter.
How much oil should it hold from empty?
How much will a 8 inch converter retain when not removed from the trans and the oil is drained?
Also when is the best time to check the level?
Rod
You should be able to get from 7 to 10 quarts in it.
If a convertor is drained not much fluid will remain.
Fluid level is checked hot, running in Park.
I always verify the dipstick is right then go by that . Full should be at or just above the pan rail level.. Best checked engine running in Park or Neutral at operating temp or close to it .
