1 - 9 of 9 Posts
How many turns should I tighten my crane roller rockers on a fully adjustable valve train with Ford hyd. roller lifters ? I initially set them at 1/2 turn past the point I felt friction on the pushrod. The rockers seem noisy, is this normal for rollers? They aren't clacking like a loose lifter but are noisy like a mechanical cam sort of is.
Discussion Starter · #2 ·
Has nobody put roller rockers on their 5.0 yet ?
There will be a bit of noise. Was the engine just fired? Or is this an engine thats been running for some time. Are you sure they are not touching the valve covers.
If all of this checks out all right, I'd go back and back each one off until it ticks and then 1/2 turn in. Thats as good as it will get.
The engine is brandnew I just needed to know if 1/2 turn was enough and I'm not looking forward to splashing hot oil all over my new headers and freshly painted engine compartment oh well guess thats what rags wre made for!
P.S valve covers are Edelbrock Elites that I tested with putty to make sure!
As for adjusting,I cut out an old set of covers and use them when I adjust,keeps the oil from splashing and ruining the paint,as for adjuments,the 1/2 turn most always works.
Jax
Guess I'll just have to take off my dress and do it Thanx.
Geofordman, it sure is nice to see somebody else from Alberta on this board but it's even nicer knowing you have the same car as me. Ever make it to Edmonton
Wow, Alberta. I've got family all over that area, Edmonton mostly. Eitehr of ya know anyone from the Zook family?
1 - 9 of 9 Posts
