Does that mean the shaft member assembly comes loose from the front side on the 9 inch?
1964 Galaxie 500 stock 289 3spd auto, Black Suede with Red Flames
1964 Falcon 4 door, dead 200 Cid 6, Blue and White Grandma Car
<font size=-1>[ This Message was edited by: desertdroog on 1/10/02 4:00am ]</font>
I don't think Ford made 9" rear axles in 85. Your F150 has either an 8.8 or a dana. both have a bolted on rear cover. I would suggest that rather than changing the gears in your axle, you get an axle from a junk yard F150. Then you can Bolt it in with no need for doing the close tolerance work needed to replace your ring & pinon.
Being that it is a 3.08 gear it is almost certainly an 8.8" rear.
Ford discontinued the 9" rear in 1987. It was in the trucks until the early 80's, but I'm not sure when the change was made, but knowing Ford they use the 9" until they ran out of the correct width and then changed over.
The 9" was available in E series vans until '87.
Later,
David Cole
I have a '86 full size Bronco with a 9",so I know they still used them in '86. I thought that was the last year.
