Below is a list of parts I have to assemble my motor. On top of these parts I have all of the nessecities for assembly (gaskets, oil pump, Cloyes timimg set, ect….)
Block: 66 289 fresh bored to .030, align honed
Rotating assy: 289 crank and rods fresh grind .010/.010
OR
302 crank and rods fresh grind .010/.010
Pistons: El Cheapo cast flat tops with 4 valve reliefs. Installed they were about .030 in the holeOR
TRW L2249N.030 domed.
Heads: 351W pedestal mount 69cc chamber. Some light porting work done. Good valves and Comp springs. Stock steel rockers(pedestal)
OR
NIB Edelbrock E Street aluminum heads with Comp full roller rockers
Intakes: Performer 289 OR RPM Airgap OR PP Hurricane (Vic jr knockoff)
Cams: Stock grind OR XE268H (ls 110, dur @ 050-I224/E230 Lift:I 509/E512)
OR Magnum 292H (ls 110, dur @ 050-244/244 lift 534/534)
[Keep in mind budget on top of these parts is $0.00. Car is a 64 Falcon, some track time (10 trips a year) 3.89 gear(9 inch), 245/60/14 tire, close ratio 4 speed(t10 with some internal upgrades).
How would you build it? No adding any other parts. This stuff is all sitting in my garage.
Cheers
Matt
Edit: My time is free to me so port matching ect.. can be added to these list of goodies. All fasteners are ARP (main studs. head bolts, rod bolts) Engine will see 6K rmp regularly.
OR
OR
Cheers
Matt
